A little help needed to complete dark theme for MP
Eyael
Post by Eyael »
Hi !
I've managed to get everything I wanted for my dark theme for MP to look exactly how I wanted it to except for selections which are still blue (I'd like them green which is the default selection color of my Windows theme) but I just can't figure out how to do it so anyone who could help would be highly welcome.
Screen caps (blue selections would be preferred green):
Windows XP Professional SP3 32 bit
Re: A little help needed to complete dark theme for MP
You means the selection in detail view, here?
Eyael wrote: Image
I believe the color of the background depends on the underlying Qt theme (View » Theme) as well as on your system's color scheme, Eyael.
  • Windows + Plastique + Cleanlooks: system color scheme (i.e. navy blue)
  • Motif + CDE: black
I'm unable to find any QSS selectors which would override the system's settings :?
Eyael
Post by Eyael »
XnTriq wrote:I believe the color of the background depends on the underlying Qt theme (View » Theme) as well as on your system's color scheme, Eyael.
Strange if so because the default color selection of my Windows theme is green not blue. Anything I select in Windows is green NOT blue so there must be something.
Vapavite123
Post by Vapavite123 »
Peut être ceci !
http://user.services.openoffice.org/fr/ ... &mode=view
XP sp2 :
Bien à vous
Eyael
Post by Eyael »
Bonjour !
Merci à vous mais je ne comprends pas le rapport. Mon thème Windows n'est pas un des thèmes fournis avec Windows et le vert de la sélection n'a rien à voir avec le vôtre. :wink:
Et j'ai toujours eu ma sélection en vert et ça n'a aucun effet sur XnView alors que dans les autres applications non skinnées, toutes les sélections se font bien en vert.
Currently an issue with Qt
Vapavite123
Salut Eyael,
Vous le dite en effet
Eyael wrote:Strange if so because the default color selection of my Windows theme is green not blue. Anything I select in Windows is green NOT blue so there must be something.
Et dans la vue Vignettes + détail, je n'arrive pas, tout comme vous, au résultat excompté
Sorry et @+
Eyael
Post by Eyael »
Vapavite123 wrote:Salut Eyael,
Sorry et @+
Bonsoir Vapavite,
La raison pour laquelle votre vue Vignettes + détail différe de la mienne vient certainement du fait que j'ai, d'une part, modifié le thème Dark fourni avec XnViewMP et également parce que j'ai modifié les couleurs via les options. Mais bon cette histoire de bleu, si on ne peut pas la solutionner, cela n'a aucune importance car c'est vraiment un détail infime. Je posais la question juste au cas où quelqu'un aurait pu m'aider mais il y a sûrement d'autres choses plus importantes à corriger dans XnViewMP. Un grand bravo à Pierre qui se décarcasse vraiment pour reproduire les bugs bizarres que nous lui envoyons. Il n'en parle pas beaucoup sur le forum mais il travaille dur et il est toujours prompt à répondre et à aider. Bravo Pierre, c'est un plaisir de tester pour vous!
