Help! INI File has Disappeared!
andrewj
Post by andrewj »
I've just upgraded to 1.99, and my INI file has disappeared altogether. It's not in:
"C:\Program Files (x86)\XnView" (where it should be)
C:\Users\Andrew\AppData\Roaming\XnView
C:\Windows
Any idea what's happening?
Thanks
Andrew
Re: Help! INI File has Disappeared!
In About, you have the full path of .ini
andrewj
Post by andrewj »
That's the one which showed me it should be in the program files directory.
I changed the settings to save to "user", and a copy re-appeared, but it had lost some changes I made yesterday.
I think there's still a bug in your logic to move settings between the different possible locations.
Thanks
Andrew
You have changed from what? to user?
andrewj
Post by andrewj »
When I couldn't find the files first I tried changing from "user" to "program". When I couldn't find an ini in either location I changed back from "program" to "user" and one turned up in the user directory, but missing some of my latest changes to companion files.
Does this make sense?
Thanks
Andrew
