GIF-Animation-Loop in Slideshow stops
korreal
Post by korreal »
I use version 1.99.5 of XnView on WinXP and there is a problem with GIF-Animations during slideshows and quick-slideshows:
GIF-Loops
(this for example
http://upload.wikimedia.org/wikipedia/c ... n_book.gif
but also really all other gif-animations)
will always only play once and then never restart.
This problem never occurs in normal view mode or in previews, only in slideshows.
This problem exists for a long time (from at least 1.8X).
Maybe XnView internally handels slideshows as animations so it creates a problem, when there is a animated loop in there? Only a vague guess...
Thank you for this program and all your hard work! :)
Best regards
korreal
Re: GIF-Animation-Loop in Slideshow stops
Post by korreal »
Any reactions? Will it be fixed?
I'll check...
korreal
Post by korreal »
Thank you :)
korreal
Post by korreal »
This bug is still present in the 2.00 version.
Please please please fix this, I use it very often!
Best wishes!
korreal
Post by korreal »
Any changes in this? The issue is still there in Version 2.04...
Would really appreciate a fix!
In slideshow, the GIF is play only once, i don't use loop of gif.
