Hello
Thanks for the new version!
I observe a scaling error in a special case:
My screen resolution is 1920 x 1080
The image is 1800 x 1800 pixels.
If displayed fullscreen with "Fit image to window, large only", i see a horizontal and a vertical black line within the image.
This problem is not new in 0.53, i observed it in 0.51 as well.
Regards,
torxx
Bug: Scaling error
torxx
Bug: Scaling error
torxx
Re: Bug: Scaling error
Additional info:
I can reproduce the black (= background color) lines on most images: they must be scaled to 48%, 60%, 75% or 96%.
Only the 32 bit Version of XnViewMP seems to be affected.
torxx
torxx
Bolthier
I experienced the same bug in the MP x64-version.
Image resolution is 1158 to 1077, scale is 88%.
So far only noticed it with this exact resolution with any format with the below added set of elements.
http://img51.imageshack.us/img51/3402/s ... 141332.png
Gav80K
I have this problem as well, and it seems that when viewing certain resolutions you can get vertical and/or horizontal black lines:
For example, I created this 1690x2450 blank image:
http://sadpanda.us/images/1469667-HKO7NJO.jpg
When I view it in full screen mode on my 1920x1200 monitor I get a horizontal black line:
http://sadpanda.us/images/1469668-BKTDHPK.png
You can also get vertical lines at some resolutions.
- Forum Librarian
This is a known bug.
