Editing an images loses its transparency
- Brother Gabriel-Marie
This is a bug that's been in XnView for years.
If I have a png or gif with a transparent background and edit the image in XnView, either by changing its color mode or anything else, when it is saved, the transparent background is changed to white.
The problem persists in version 1.996
Re: Editing an images loses its transparency
Hi, Mr. XnView. If I change from color RGB to greyscale, the transparent background turns to white. The thumbnail also loses the transparency.
I can confirm this because it is even white when I open the files in Photoshop. I had the same problem on my old XP as I do now in Windows 7 x64.
8bits picture has no transparency mask in Xnview
Workaround:
- Download logo.png (32-bit RGBA) and open it in XnView MP.
- Go to Image » Change color depth... and select 24 bits » OK.
- Go to Image » Change color depth... again and select Greyscale [256] » OK.
- Save the result as greyscale.png.
- Open logo.png once more and go to Image » Extract channel » Alpha.
- Save the result as mask.png.
- Go to Tools » Batch convert... and specify the following settings:
- Input
- Actions
- Image » Add mask
- Mask: [mask.png]
- [√] Use mask as alpha
- Image » Add mask
- Output
- Format: [PNG]
- Input
Left to right: logo.png + greyscale.png + mask.png + greyscale_result.png
I'm a little confused - so when I change a RGB file to Greyscale in XnView, then is it supposed to lose its transparency? I don't want it to do that. I am forced to open the file in Photoshop to change the colours. I don't want to do that either.8bits picture has no transparency mask in Xnview
And it's not just the masking for the thumbnail. If I change it to greyscale, the transparency is completely lost - I can see it lost when I edit it in Photoshop. I have to edit the file again in order to fix it.
Also, an 8bit image with transparency does not display its transparency in XnView in "View" mode, although it *does* in thumbnail mode.
It is the same problem either with an 8 bit image OR a 16bit image.
If the thumbnail does not show its transparency, which it doesn't at first, it *will* if you a "rebuild thumbnail" on the file (or files in the folder).
In my (humble) opinion, whether 8bit OR 16bit, if I change the colour from rgb to greyscale, the transparency should be preserved, AND the thumbnail should be automatically rebuilt.
This is a known limitation. It was fixed in XnView v1.97 for 8-bit color PNGs + alpha-channel transparency, but the issue persists with grayscale + alpha channel.Brother Gabriel-Marie wrote:Also, an 8bit image with transparency does not display its transparency in XnView in "View" mode, although it *does* in thumbnail mode.
@XnTriq, thanks for the confirmation (I *knew* I wasn't crazy), and the for the info (and for fixing my image-link).
I use XnView to view png files all the time. Sometimes the png files will show the transparency in the thumbnail, sometimes they don't. Most of the time they don't show the transparency in preview mode. And this happens even if I don't edit them in XnView.
I am having this problem with png files made by exporting from Adobe Illustrator CS5 (Windows 7 Pro x64; 16gb RAM; XnView 2.10)
If I rebuild thumbnails, the transparency seems to get fixed on the thumbnails, but I have to do it over and over to the same images. And that doesn't help the preview.
Is there some setting somewhere to make the transparency rendering consistent?
Hi folks! I'm back to this again; hoping circumstances are okay now to get a fix.
Version 2.25
So I have some png files with transparent backgrounds.
24 bit RGB
When I adjust the gamma/contrast of the image and save it in xnview, all the transparency is turned to white.
This problem is in the image file itself - not just the preview.
Version 2.25
24 bit RGB
Could you post a sample, Br. Gabriel-Marie?Brother Gabriel-Marie wrote:So I have some png files with transparent backgrounds.
24 bit RGB
Ak! I tried to upload my sample files, but the forum says
"Image file type mismatch: expected extension jpg but extension png given" - I've had that before. PITA.
If I upload them to imgur, the transparency gets scrapped there, too.
Maybe I could email them to you...
But this is an example of sorts:
Might upload successfully in a ZIP (or RAR) archive?Brother Gabriel-Marie wrote:Ak! I tried to upload my sample files, but the forum says
Okay, I had to use different images.
Here is a zip file.
Here is a zip file.
- Attachments
- transparency_loss.zip
- (501.36 KiB) Downloaded 175 times
I can't reproduce
What I done did:
What are your settings in Tools » Options... » Read/Write » Write » PNG » Parameters, Br. Gabriel-Marie?
What I done did:
- Fired up XnView v2.25
- Went to Image » Adjust » Brightness/Contrast/Gamma/Balance...
- Set Contrast to 127
- Set Gamma correction to 0.50
X:\>FC /B opossum.png opossum_export.png
FC: no differences encountered
