Copy transparent image onto another image
btakacs
Post by btakacs »
Please support to copy a transparent image onto another image.
XnView solved many of my image-editing issues: resizing, bluring, putting arrows and frames to a picture.
Last time I wanted to put a small icon onto a bigger image. The small icon had a transparent background but I could not copy it to the bigger one without loosing this transparency (instead of the transparent background it became grey).
Actually if I copy the same picture into Photoshop it does not carry transparency neither (but if I open the original picture it displays the transparent parts as transparent).
I searched the internet, and found out that with the watermark wizard I can do the same, without resizing.
So please support that feature. Either
- by copying the alpha channel information to the clipboard when pressing Ctrl+C
- or by adding a resize possibility to the watermark wizard
btakacs
Re: Copy transparent image onto another image
Post by btakacs »
822 views means that it is interesting for many people.
But no response...
Please support that request with your comment if you think this would be useful!
btakacs
Post by btakacs »
Original version in XnView and two versions: (1) opened directly from Word and (2) selected and copied through clipboard
Copying image with alpha in clipboard is always a problem with Windows, the last version support copying 32bits picture.
But i have not Word to check this bug...
btakacs
Post by btakacs »
Some more experimenting: copying the same image into XnView itself
btakacs
Post by btakacs »
The file used:
[img]remote_icon.png[/img]
