file format support for cmx
guest
I see, both from your website and from help file, that XnView supports the file type cmx (Corel Metafile Exchange), but when i want to associate this file type in the option screen, I can't find a checkbox for cmx! May anyone help me with this?
With…
- Indeed, if *.cmx is missing in the list of associations, you might use other ways as workarounds :
1. Make a double-click on the non-associated file in Explorer or a file manager, wou might get the Windows dialog asking for open the file with …
- There is a tick-box like "Always open this file type with…" or so.
2. If you have Total Commander, you can associate that file-type with XnView : Files menu >>> Associate with… then follow the dialogs.
- Get a Quick View in TC (F3): you could view (only) these files too when XnView is used as the multimedia addon. You must add in the file <wincmd.ini> :
Hoping this help,[Lister]
IviewAdditionalTypes=*.cmx
