<Ctrl+D> in Viewer and Browser
halfmann
Post by halfmann »
XnView is almost perfect. I really like it! But there is one annoyance:
If I hit <Ctrl+D> in Viewer mode, the dialog "Edit description" appears. If I do the same in Browser mode, the "Set comment" dialog appears. The first dialog entitles me to edit the description stored in descript.ion, while the last one entitles me to edit the description in descript.ion as well as the embedded comment stored in the metatags. I prefer the last dialog, it's clearer what will happen...
In Viewer mode there are two menu entries: "Describe..." and "Edit comment...", in Browser mode there is only one menu entry "Edit Description/Comment...".
Is it possible to make the two modes behave the same way? I would like to hit <Ctrl+D> in both modes (or use the same menu entry "Edit Description/Comment...") and see the "Set comment" dialog in order to edit both comment and description.
