Opening .PCD files at different resolution levels
Psychoochef
Post by Psychoochef »
I have several old Kodak Photo Discs and they have each image stored in a .PCD file which contains multiple resolution levels of the same image in each file. When I use XnView to open the files I am only able to view the smallest resolution. Is there a way to have XnView open any of the other resolutions contained in the original files? I am using a Mac running OSX 10.5.8.
****thank you for this program since without it I couldn't view the .PCD files on my Mac at all.
Sorry, I appear to have posted this in the wrong section of the forum, I hope to get an answer anyway....please.
Re: Opening .PCD files at different resolution levels
Only a PCD plugin exists for windows
Psychoochef
Thank you, do you know where I can get that plug-in? I will have to open them on my PC and move them to the Mac...I'll live through the extra steps.
