'Next file' and 'Last file' have different response speed
ZF Tang
Post by ZF Tang »
I installed version 1.80.1 on my win2000 system.
When I explorer a directory containing about 5000 image files with ppm format (size 352x288), I found that the program's response to pagedown key (next file) is slow than that to pageup key(last file).
Is this a bug?
Dreamer
Post by Dreamer »
Try this:
Options > View > File List > Cache - enable both options here
ZF Tang
Thank you
Post by ZF Tang »
It works after both options disabled.
Dreamer
Re: Thank you
Post by Dreamer »
ZF Tang wrote:It works after both options disabled.
Strange...
Re: Thank you
You have disabled read ahead/cache behind and now "next file" is quicker than before???
Re: Thank you
Post by Guest »
Maybe my description about the problem was not correct.
If the first option is enabled, the program will keep no response for several seconds before displaying the next image after I press the 'Next file' button.
Enabling the second option does not cause the problem.
I also tried a directory containing 200 image files, this problem didn't occur.
Re: Thank you
In which mode do you are? View or browser? In fullscreen?
So you have only "read ahead" to reproduce it?
zft
Re: Thank you
Post by zft »
xnview wrote:
Anonymous wrote:
xnview wrote: You have disabled read ahead/cache behind and now "next file" is quicker than before???
In viewer mode.
Yes. just when the 'Read an image ahead' option enabled
Re: Thank you
zft wrote: In viewer mode.
Ok, :bugconfirmed:
