Configure and move Toolbars, Tabs, Menu...
Olivier_G
Post by Olivier_G »
I know that it would be a lot of work, but the possibility to configure completely all elements on the screen would be a great improvement:
- configure each bar (Toolbar, small toolbar above main area, Menu, Tabs) and even move elements between them
- move and dock them anywhere in the window
If this is not possible in the short term, please consider the following improvements:
- possibility to hide the small toolbar above the main area
- possibility to move Tabs ("folder tabs") just to the right of the Menu (same line)
- possibility to show the status info into the Title bar, right-aligned
=> this would be an easy way to maximize the main area.
Thank you,
Olivier
Olivier_G
Re: Configure and move Toolbars, Tabs, Menu...
Post by Olivier_G »
Olivier_G wrote:- possibility to hide the mini toolbar (above the browser window)
Pierre: wouldn't some of those suggestions be easy to implement?
(I am thinking about the first two).
Olivier
More for---
:) Hello !
- I support ! Indeed, a bunch of options that could be processed with THAT. ;)
:mrgreen: Kind regards, cordialement,
Olivier_G wrote: If this is not possible in the short term, please consider the following improvements:
Yes currently a lot of work to make that :-(
Ok
Olivier_G
Post by Olivier_G »
Thank you, Pierre. :D
herr_k.
Post by herr_k. »
kris wrote:2. adding an option to keep the toolbar in the view mode, but hide it in the browser mode. nice would also be, if you could move the toolbar besides the menu, so there is more space for the picture.
support.
