Can I Multi-page Tiffs as multiple PDF's?
Warmace
Post by Warmace »
I've searched the help file and browsed the forum with no luck.
I receive a lot of multiple page TIFF files (from a digital fax), and would like to be able to save them as single page PDF's for cataloging.
Is this possible with XnView Classic or NConvert? I figured out how to save a 3-page Tiff as a 3-page PDF, but I need to make it individual files, and hopefully automate the process.
Re: Can I Multi-page Tiffs as multiple PDF's?
yes, with Create>Multipage
Warmace wrote:I receive a lot of multiple page TIFF files ... and would like to be able to save them as single page PDF's
... I need to make it individual files...
You want to convert a [seven] page M-TIFF file into [seven] single page PDF files?
Tools > Multipage file > Extract All Into...
The PDF compression method used for the files created can be set in Tools > Options...
Warmace wrote:... and hopefully automate the process.
I don't see a way of doing that using Tools > Batch Procesing...
But it should be straightforward using NConvert: use -xall to extract the images and note that there are limitations on the use of spaces in [output?] file names.
