Missing scanning option
lutfi9
Post by lutfi9 »
With XnView 0.68 on Windows 7 Pro 64 Bit there is no scanning function. Will this be implemented soon?
Re: Missing scanning option
lutfi9 wrote:With XnView 0.68 on Windows 7 Pro 64 Bit there is no scanning function. Will this be implemented soon?
Due to a lack of TWAIN 64-bit support in Windows, the only way in practice to scan from XnViewMP is using the 32-bit version; it's not an XnViewMP issue but more general. You can have both 32-bit and 64-bit editions of XnViewMP installed at the same time, if you wish...
