I am trying to put a logo on my photos.
I have been using the filigrane command in the convert menu with the attached png file.
The problem is that when I do this, this does as below (I used pink to clean the logo before saving it as a png...).
Any solution?
Filigrane with transparent colour (png file)
Bebmoumoute
Re: Filigrane with transparent colour (png file)
You are using XnView 'Classic' [v2.22 for example] with the French language selected? Not XnViewMP or XnConvert?Bebmoumoute wrote:I am trying to put a logo on my photos. I have been using the filigrane command in the convert menu with the attached png file.
Any solution?
Could you please describe in more detail the result you wish to obtain...
You may possibly find the following link useful:
http://faq.jalis.fr/images/ajout-dun-fi ... -de-photos
- Forum Librarian
Image > 32 bits (English or French language interface) can be used to convert a 24bit image to 32bit for this useage?
- Forum Librarian
Due to a known limitation, transparency will not be preserved in cases like this.cday wrote:Image > 32 bits (English or French language interface) can be used to convert a 24bit image to 32bit for this useage?
Edit: I've converted LOGO-small.png (truecolor + single color transparency) with an old version of Macromedia Fireworks to 32-bit (truecolor + alpha channel transparency):
Bebmoumoute
Many thanks !
