Disable "Play movie/sound" doesn't work in FS lite
Dreamer
Post by Dreamer »
Disable "Play movie/sound" doesn't work in Fullscreen lite.
Dreamer
Re: Disable "Play movie/sound" doesn't work in FS
Dreamer wrote:Disable "Play movie/sound" doesn't work in Fullscreen lite.
When you use prev/Next file? And which option do you use?
Dreamer
Post by Dreamer »
I'll try to explain:
- disable options "Play movie" and "Play sound" (in Options>View>File List)
- go to first image - 1.jpg in browser
- go to viewer or fullscreen (standard, in view mode)
- switch to next file(s)
- you can see files 1.jpg, 3.jpg, 5.jpg = no audio/video files
but...
- go to fullscreen lite (press F11 in browser)
- you can see files 1.jpg, 2.avi, 3.jpg, 4.mp3, 5.jpg = also (disabled) audio/video files
You can use any key/mouse to switch between images.
marsh
Post by marsh »
Dreamer wrote: - disable options "Play movie" and "Play sound" (in Options>View>File List)
Preview only uses Browser>Preview>'Play movie' option.
Dreamer
Post by Dreamer »
But both fullscreen modes should be the same...
Normal users will not search this "fullscreen" option under Browser>Preview...
Yes, right. There is some mistake with options.
And perhaps it's not needed to have Play movie/sound for view & preview, 'high quality', display PDF/EPS/PS files too. Perhaps only ONE setting in options/View will be better... What do you think?
Dreamer
Post by Dreamer »
xnview wrote:Yes, right. There is some mistake with options.
Maybe, but I'd prefer the same option as in Options>Browser>File List also for View>File List (there is enough space there):
Items shown in view mode:
[x] Video
[x] Audio
[x] PDF/EPS/PS
[x] Folders *
[x] Archives **
[x] all other files
maybe also:
Items shown in fullscreen mode:
[x] Video
[x] Audio
[x] PDF/EPS/PS
[x] Folders *
[x] Archives **
[x] all other files
* - this is new suggestion, I'll star new topic for it...
* / ** - more here - Items shown in view/fullscreen mode
Danny
Post by Danny »
So what about this? I can't possibly prevent video files from showing up in the viewer and fs-preview at the moment.
Get the bugs fixed, THEN start adding features. It sucks, but someone has to do it.
