My image library has many, many duplicate images in it. I'd like to remove some, but it is hard because other image duplicate finders dont know which ones I have tagged or not. It would be nice if there was a build in function to allow us to find duplicate images in our library, and see which one has more tags.
Thanks
Duplicate finder
Marsu42
Re: Duplicate finder
Surely "nice to have" in XnView, but try "dupeGuru Picture Edition" for an existing excellent choice.FOTerminite wrote:My image library has many, many duplicate images in it. I'd like to remove some, but it is hard because other image duplicate finders dont know which ones I have tagged or not. It would be nice if there was a build in function to allow us to find duplicate images in our library, and see which one has more tags.
Imho the one thing that XnViewMP should be *really* able to do is detect exact dupes on copy/move, the current behavior of letting the user click "skip" each time on 100% equal pictures is bordering on stupidity.
Janakatta
More duplicate functions would be great.
+1 Computer can do wonderful things but they still ask the user whether an identical file should be overwritten or not. :-/ (E.g. Comparison pf file size + MDI5 checksum on parts of the file could be used to verify identity.)Marsu42 wrote:...Imho the one thing that XnViewMP should be *really* able to do is detect exact dupes on copy/move, the current behavior of letting the user click "skip" each time on 100% equal pictures is bordering on stupidity.
m.Th.
m. Th.
m.Th.
Hmmm... yeah, nice program. However it is in the same ballpark with other similar programs. What would be a killer feature is to have already the file signatures (hashes) in the catalog, hence when you copy/move (like you say) or, more generally, when you add a picture to the catalog, the new entries would be compared with the existing ones in the catalog - thing which would be much, much more faster than the simple all-to-all compare process which dupeGuru (or any other program) is forced to use.Marsu42 wrote:Surely "nice to have" in XnView, but try "dupeGuru Picture Edition" for an existing excellent choice.FOTerminite wrote:My image library has many, many duplicate images in it. I'd like to remove some, but it is hard because other image duplicate finders dont know which ones I have tagged or not. It would be nice if there was a build in function to allow us to find duplicate images in our library, and see which one has more tags.
You can use 'Skip All' perhaps??Imho the one thing that XnViewMP should be *really* able to do is detect exact dupes on copy/move, the current behavior of letting the user click "skip" each time on 100% equal pictures is bordering on stupidity.
m. Th.
Marsu42
Nope, not when the finenames are generic. Imagine researching the net for files of a certain theme, you end up with 01.jpg and the like. Now cull these with xnvew, i.e. copy selected ones to a destination folder already containing multiple 01.jpg ... 01(01).jpg and so on. Ideally, it should be able to auto-skip or auto rename all these ...m.Th. wrote:You can use 'Skip All' perhaps??Imho the one thing that XnViewMP should be *really* able to do is detect exact dupes on copy/move, the current behavior of letting the user click "skip" each time on 100% equal pictures is bordering on stupidity.
... but really, a very basic "skip comparison dialog on move/copy" should be rather easy to implement? XnView asking you about "would you replace this identical file with the other identical file" feels so stupid and is a waste of time ... just sayin'
