Image Resize
KayJ
Image Resize
Post by KayJ »
I have a question about image resize. :idea:
XnView provides the Lanczos algorithm.
However, the other viewer, FastStone Image Viewer, provides the Lanczos3 algorithm.
From the literal meaning of view, I think Lanczos3 is better than Lanczos. :wink:
Are they the same algorithm? :?:
Drahken
Post by Drahken »
I don't know which lanczos xnview actually uses, but a bit of research reveals that the number at the end indicates quality/speed. The higher the number (google turned up ones as high as lanczos5), the higher the quality, and the more time it takes to perfrom the resize.
Post by Guest »
o... thank you. :P
I hope that XnView will support lanczos1 to lanczos5 soon. :D
Anonymous wrote:o... thank you. :P
XnView use Lanczos3
