Web page creation: Choose template folder does not work
TorstenT
Post by TorstenT »
Hej,
in XnView version 1.80.1, there is a box "Template Folder" in the "Web page Create" window (BTW, typo: "page" -> "Page"). To the right of it, there is a button "..." which opens a file dialoge, supposed to be a chooser for the template dir, right?
But the file dialogue seems to be a completely different one: :shock:
(1) It has the title "Output Directory" and
(2) no matter what I choose in there, it does not affect the list of templates listed in the "Template" list box
Luckily I can change this directory via the xnview.in file! :wink:
Regards,
Torsten
Torsten Thießenhusen
callto:TorstenThiessenhusen (Skype)
ckv
Post by ckv »
Yeah you are right. :bugconfirmed:
Better in 1.91.6
The behaviour has improved (one can switch the template folder) though the combobox with the templates listed becomes a real mess:
The templates of the new template folder are listed (o.k.) AND the templates in the old folders are still listed (bug :bug:).
