[Solved] Thumbnail size doesn't work proper
neoprana
Post by neoprana »
Hello
When I try to change Thumbnail size it works to about 150-200 pixel, after that the box will get bigger and not the Thumbnail itself... refreshing does not change anything... even if i move to new fresh folder the Thumbnails stay tiny small :bugfixed:
It seems XnView do not scale ALL thrumbnails proper may? Some are big some stay small
HMMM already found the solution/OPTION: Create thumbnail from orginal image if embedded is smaller....
