select all (ctrl-a) selects the ".." up-a-folder t
loth
Post by loth »
hi,
not a big-bug, but worth to mention.
go with the browser into a folder.
press CTRL-A to select all files and recognize, that the ".."-folder is also selected.
this could irritate the user if he/she wants to delete all the files in that folder:
.oO(hmmm. will xnview delete the folder as well, or all the foldes above?)
loth
•• not deleted…
:) Hello !
- Right, the •• parent directory is selected too.
- When you delete all files, it stays simply as is… :P
- However, it could be possible to prevent that •• be selected, since I tested in Total Commander with a thumb-nails view : there, it is not…
:mrgreen: Kind regards,
Dreamer
Post by Dreamer »
I agree.
loth
Post by loth »
the years past, i found this topic per accident :-)
the this little bugger is still in 8->
