only viewing small DNG file
jcogbil
Post by jcogbil »
I am having issue with XnViewMP vers 0.72 x64 viewing DNG files created with my Canon SX230HS (running CHDK 101e). The output should be DNG 1.3 compliant. The file opens without issue using Adobe Photoshop CS5 and displays correctly using the default image viewer in google drive. The photo displayed by XnViewMP is 128x96 but should be 4000x3000.
Attached is a link to an example file as well as the jpg which was created by the camera at the same time.
https://drive.google.com/file/d/0BwhPF8 ... sp=sharing (dng)
https://drive.google.com/file/d/0BwhPF8 ... sp=sharing (jpg)
My apologies if this issue has been addressed previously but I could not find any mention of it on the board and nothing helpful on the web as well.
Thanks
-Jim
Re: only viewing small DNG file
please change in the view settings 'Camera raw' => embedded preview
mrmerrick
Post by mrmerrick »
I'm having the very same problem, however it doesn't matter if I change that setting to show half or full size: the image will always show very small. These are DNGs exported from Lightroom. Maybe it's because they are "lossy" DNGs, that were introduced not too long ago by Adobe?
Thanks in advance.
P.S.: Love the program, just discovered it exists after 10 years of using XnView. This is so much faster!
mrmerrick wrote:I'm having the very same problem, however it doesn't matter if I change that setting to show half or full size: the image will always show very small. These are DNGs exported from Lightroom. Maybe it's because they are "lossy" DNGs, that were introduced not too long ago by Adobe?
Thanks in advance.
mrmerrick
Post by mrmerrick »
Sure, just sent it to you via PM. Many thanks!
gregambrose99
Post by gregambrose99 »
I have the same problem with importing a DNG.
Did you manage to role this problem?
I hope so as I love every other aspect of this software Very well designed.
Thanks,
Greg
please send me a dng file?
