(However Honeyviewer sucks for me because it has NO file browser)
Thanks!!
[Hidden]
MenuBar=1XnView Wiki (UI-less Settings » [url=http://www.xnview.com/wiki/index.php/UI-less_Settings#Hidden]Hidden[/url]) wrote:MenuBar
- When enabled, XnView hides the menu bar.
Value: Boolean (1/0), disabled by default
Thanks!XnTriq wrote:
- Go to Info » About... to find the INI file location.
- Quit XnView.
- Open xnview.ini in a text editor (e.g. Notepad).
- Add the following lines to the end of the file:
[Hidden] MenuBar=1- Save the changes.
- Restart XnView.
You can toggle the status bar's visibility with Ctrl+Shift+B or with the corresponding command in the View menu.davesurfer wrote: Now just need to get rid of the program bar and status bar lol.
Cool thanks! That gets rid of the status bar.XnTriq wrote:You can toggle the status bar's visibility with Ctrl+Shift+B or with the corresponding command in the View menu.davesurfer wrote: Now just need to get rid of the program bar and status bar lol.
