I can open a .jpg with XnView, copy (CTRL+C) and paste it (CTRL+V) in MS Word 2010 but it's not working with png files. I don't know if it was possible before because I'm using this function quite often and I was never anoyed before.
I'm under Windows 7 Pro x64
Thanks
[Solved] Copy/paste png to MS Word 2010
Re: Copy/paste png to MS Word 2010
No problem for me in a quick test using XnView Classic 2.34 or 2.13, or using XnViewMP 0.75 x32 ...Icarus wrote:I can open a .jpg with XnView, copy (CTRL+C) and paste it (CTRL+V) in MS Word 2010 but it's not working with png files. I don't know if it was possible before because I'm using this function quite often and I was never anoyed before.
Windows 7 x64 and MS Word 2010.
Possibly an issue with transparency??cday wrote:No problem for me in a quick test using XnView Classic 2.34 or 2.13, or using XnViewMP 0.75 x32 ...
If necessary, could you upload the PNG file -- in a ZIP to ensure that it isn't modified -- for someone to test?
Sorry for the delay.
The file is in attachement. I don't know if it's related to MS Word, if I convert the PNG to JPG it's working, but if I convert to BMP it's not working as well.
I'm using the .zip version, mabe the install version registers some files.
- Attachments
- Capture84.zip
- (22.28 KiB) Downloaded 254 times
Your file pastes into Word 2010 normally for me, which seems to eliminate a number of possibilities...Icarus wrote:The file is in attachement. I don't know if it's related to MS Word, if I convert the PNG to JPG it's working, but if I convert to BMP it's not working as well.
Windows 7 x64 and MS Word 2010 (Starter Click and Run).
Have you tried Googling, one slightly confused post related to pasting images suggests checking the following Word setting is unchecked:
File > Options > Advanced > Show document content > Show picture placeholders
Don't know if that has any relevance, but other search returns might...
No, it does not work.
I can paste PNG files to MS Paint but not to MS Word. I don't know if the problem is related to MS Word (because Irfan View is OK) or to XnView (because MS Paint is OK)
Have you given Paste special a try, Icarus?
I tried the Paste Special and it works with the first choice : paste as Bitmap.
According to this doc this option is related to transparency so I tried to look for a transparency option for PNG files in XnView.
I finaly discovered that in the XnView menu General > Read/Write > Read > PNG, "compose image with transparency" and "compose image with alpha (32 bit)" were inactives. If I activate these both options the copy/paste to Word 2010 is working.
Thanks for you support.
Glad you have found a solution...Icarus wrote:I tried the Paste Special and it works with the first choice : paste as Bitmap.
The fact that the PNG image you originally uploaded pasted into a Word 2010 document on my computer by simply selecting the downloaded file, and then using Ctrl-C and Ctrl-V, seems to imply that the problem pasting the file that way on your computer is due to a different setting somewhere in Word, or just possibly due to a different update state.
