move or copy to new folder
loth
Post by loth »
hiho,
i'd like to suggest the following feature:
i often have to move files from a folder to its subfolder, or to a new subfolder which i name after the filenames i move into that new created subfolder.
now in XnView, i have to select all the files i need,
press STRG-X to cut them into the clipboard, and
press F7 to create a new folder,
browse into that folder, and
press STRG-V to move the files into it. then i have to
go outside that folder an have to manually scroll to the last position the cursor was, before i created a new folder. to keep working...
this is a lot of work for a simple thing ;=)
i'd prefer a way like this:
select all the files and
press ALT+M.
activate that little option which is called:
'create a new folder an move/copy files into it' or (another spelling) 'copy/move files into new created folder'
or press the button called 'move/copy files after creating a new folder'
something like that.
this would save some time and clicking.
anybody any suggestions/ideas?
loth
Olivier_G
Post by Olivier_G »
Currently, there is a good way to do it:
- select the files and use 'Move to Folder'
- choose the right directory, select 'new folder' and name it
- press 'Move'
...it is very close to what you suggest.
Olivier
loth
Post by loth »
Olivier_G wrote:Currently, there is a good way to do it:
- press 'Move'
Olivier
yes it is, and if i named the new folder, i just click on the button "move" instead of enter, and the files are directly moved. the cursor is still on its position, which is correct too.
i wonder why i didnt reccognize that easy way 8-)
thanks mate
loth
