Grid lines appearing with Alpha on TGAs
insyami
Post by insyami »
I've used XnView for quite some time, and decided to try out XnViewMP because its UI is a little bit more polished and straightforward, however, I'm having what I believe is a bug when previewing TGAs with the alpha channel enabled. Here is the same file open on both XnView and XnViewMP with the Alpha channel disabled:
Everything looks fine, but here's what happens when I enable the Alpha channel:
Lots of grid lines appear over the image. They disappear if the zoom is on 100%, but appear again as soon as I zoom in or out, which makes me believe it's an issue with how the zoom function works.
Re: Grid lines appearing with Alpha on TGAs
yes a known issue
jumo
Post by jumo »
It seems, I got the same issue on PNG.
It becomes very inacurate on few pixel wide images:
(eg: Image)
Is there any plan to fix it ?
Timmyfox
Post by Timmyfox »
Still having this issue on 64-bit MP-version with PNG files, driving me nuts..
This problem is supposed to be fixed in XnView MP 0.84. Could you (insyami / jumo, / Timmyfox) please try and confirm the bug fix?
Related bug report:
- 0.68: Discontinuities when downscaling large images
