Sort Favourites
Lesmo16
Sort Favourites
Post by Lesmo16 »
I like to suggest an additional Button in the "Edit Favourites" window, which does a basic alphanumerical sort of the favourites.
Everyone who believes in telekinesis, raise my hand!
Re: REQ: Sort Favourites
Lesmo16 wrote:I like to suggest an additional Button in the "Edit Favourites" window, which does a basic alphanumerical sort of the favourites.
Ok
Made by hand !
:arrow: Lesmo 16
:) Hello !
- I guess you mean something like this :
———————Image
- Waiting for a sorting option in the “Edit favourites” dialogue, you can sort this by hand.
Simply edit the file : …\ …\Application Data\XnView\bookmark.ini
- Indeed, it's easy if you have not dozen folders here :P
:mrgreen: Kind regards,
Re: Made by hand !
Clo wrote:- Waiting for a sorting option in the “Edit favourites” dialogue, you can sort this by hand.
I do not recommend editing the .ini file unless really needed. You can sort the entries using the Up/Down buttons in the "Edit favourites.
Fates Warning
Post by Fates Warning »
Hi All.
Ive been using XnView for many many years its great !
I have recently updates to 1.90 and its very good.
However the sort feature in the Favourites sorts them but not
in a alphabetical way that looks right.
Please return the up down arrows option !
Cheers
Fates Warning wrote:However the sort feature in the Favourites sorts them but not
What is the problem??
Ok, i'll try to add it soon
Fates Warning
Thank you that would be good
Fates Warning
Thanks for adding that back in Version 1.9.02
Cheers
