'Synchronize browser selection with current view' not working with v.1.80.2RC.
edit:
Broken when using viewer, not browser fullscreen.
edit 2:
Fixed v.1.80.2
[Fixed]Synchronize browser selection broken in v.1.80.2RC
I can confirm this.
Re: Synchronize browser selection broken in v.1.80.2RC
I have not this problem, you start the browser, open a picture, Pgup, return or esp, and the selection is not the good one?marsh wrote:'Synchronize browser selection with current view' not working with v.1.80.2RC.
edit:
I think that I could reproduce the problem:
Options:
a.) View > Maximize View when Open: Deactivated
b.) Browser > Sychronize Browser selection with current View: Active
c.) Associations: Associate a file type (e.g. JPG) with XnView
1. In MS Explorer, double-click on an image file. XnView will open
2. Use "Next image" several times (1-n)
3. Open Browser by clicking on the toolbar button or menu "File>Browse"
Browser will open with correct image selected
4. Select folder tab with image
5. Again, use "Next image" one or several times
6. Switch to folder tab "Browser"
--> Currently viewed image isl not selected in browser.
Not sure whether this is marsh's problem, but this is a bug.
Options:
Helmut's example is right. 'Synchronize browser selection with current view' only works using browser's fullscreen. When browser and viewer are same in v.1.81, this may not be a problem.xnview wrote:I have not this problem, you start the browser, open a picture, Pgup, return or esp, and the selection is not the good one?marsh wrote:'Synchronize browser selection with current view' not working with v.1.80.2RC.
edit:
1. Browser > Fullscreen > Viewer
2. Advance many files with <pg dn>.
3. pressing <Enter> twice to return to browser again.
4. *The latest file is not highlighted, the starting file is.
-It works normally using browser's fullscreen only.
Ok, i'ts not a bug and it's the same in 1.80.1, i synchronise browser only when you dbl click or press enter/escape.helmut wrote:I think that I could reproduce the problem:
Options:
If you have a lot of picture opened from different folder, so when you click on tab browser, you'll have some folder changing in browser, not really good.
Here it's a bugmarsh wrote: Helmut's example is right. 'Synchronize browser selection with current view' only works using browser's fullscreen. When browser and viewer are same in v.1.81, this may not be a problem.
