Under Settings, Interface, Toolbar there is a check box for Large Icons. It does not seem to work. I first check the Large Icon box then click on the OK button, the settings box closes and a Information dialog box opens asking me to restart XnView MP. When I do this the setting has not "stuck", it reverts back to it's unchecked condition. Is there a special way that I have to restart XnView MP?
I am running the 0.79 64 bit version under Windows 10.
Large Icon setting not working.
therealgord
Re: Larg Icon setting not working.
You might check if the large icons setting has been registered in the xnview.ini file:therealgord wrote:Under Settings, Interface, Toolbar there is a check box for Large Icons. It does not seem to work. I first check the Large Icon box then click on the OK button, the settings box closes and a Information dialog box opens asking me to restart XnView MP. When I do this the setting has not "stuck", it reverts back to it's unchecked condition. Is there a special way that I have to restart XnView MP?
Tools > Settings... Integration > Paths -- XnView settings -- Open Config files Location
Then open xnview.ini in a text editor and see if this entry is present:
toolbarIcons=Toolbar-48If the setting hasn't been registered, you could possibly try an alternative xnview.ini location.
therealgord
Re: Large Icon setting not working.
Thanks for responding.
I followed your directions and the "toolbarIcons=Toolbar-48" entry is in the ini file in the "Start" section.
The ini file is located in the "User (System)" location. I don't know if that makes any difference.
Gord
Gord
And if you close XnView MP and then restart it you still have the small icons??therealgord wrote:I followed your directions and the "toolbarIcons=Toolbar-48" entry is in the ini file in the "Start" section.
I don't know if there are any known issues with large icons in Windows 10, you could search the forum if you haven't done so...
therealgord
Yes, after a restart of XnView I still have the small icons. I did search the forum but did not find any relevant posts. It could be that my search string is not very good, I will try again.cday wrote:And if you close XnView MP and then restart it you still have the small icons??therealgord wrote:I followed your directions and the "toolbarIcons=Toolbar-48" entry is in the ini file in the "Start" section.
thanks
therealgord
xnview wrote:do you have UI/icons-48 in XnViewMP folder?
Yes, there is an icons-48 folder within the UI folder.
therealgord
Sorry for the delay in replying but I was very busy during the last few days.xnview wrote:do you have UI/toolbar.ini?
The answer to your question is, no, I do not see a toolbar.ini file in the UI folder.
Gord
Please use this file
therealgord
xnview wrote:Please use this file
That worked. Thank you.
Cheers,
Gord
