I often create a picture collage e.g. of 4 pictures.
In the file browser I select 4 jpeg files.
I go to the menue: Create => join images
XN-View MP creates a correct collage of the selected files and name the picture "<empty>".
Then I want to export the picture file.
Menue: File => Export...
Nothing happend!
I think XN-View MP can not export it, because the new created picture has no name.
If I import a picture from clipboard it will get a new name "clipboard" and Number.
File export does not work after image joining - V0.79
PC: Intel 8700k + Asus Z370-F + 16 GB RAM G.Skill + Asus RTX 3050 OC + Samsung SSD
OS: Windows 10 Pro 64bit 22H2 |
GFX: XnViewMP 1.8.7 | XN-View 2.52.0 | XnConvert 1.104.0 | Adobe Photoshop Elements 2024 | Elements XXL 11 | Paint.Net 5.1.7
Re: File export does not work after image joining - V0.79
"export" must no be available, you need to use save
Export (File » Export) is available after joining images or after making a screenshot in v0.84.
Closed
