0.84: Set selection ratio
Moderator & Librarian
  1. Deactivate Rotate images according to EXIF orientation tag in Tools » Settings... » General » General.
  2. Open IMG_3256.JPG.
  3. Go to Edit » Properties...:
    • Properties » Image » Width: 4000
    • Properties » Image » Height: 3000
    • Properties » Image » Origin: Top-Left :bug:
    • EXIF » Camera » Orientation: right-top (6)
  4. Activate Same as image in Edit » Set selection ratio.
  5. If you select an area of the image with the mouse, the selection will be 3:4 although the image's ratio is 4:3. :bug:
8< – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – >8
  1. Activate Rotate images according to EXIF orientation tag in Tools » Settings... » General » General.
    • Properties » Image » Width: 3000
    • Properties » Image » Height: 4000
    • EXIF » Camera » Orientation: top-left (1)
  5. If you select an area of the image with the mouse, the selection will be 4:3 although the image's ratio is 3:4. :bug:
Re: Set selection ratio
XnTriq, I'd try to reproduce your problem but the links to the images no longer work. Could you please upload your two images, again?
Erixx haxx
Post by Erixx haxx »
Hi:
I have also seen this when working in fullscreen.
It seems to only happen when setting selection by Ratio setting, "W x H" get flipped. :bug:
Setting Selection by Pixels seem to work fine.
Thanks
Thanks for checking, Gentlemen :mrgreen:
helmut wrote:XnTriq, I'd try to reproduce your problem but the links to the images no longer work. Could you please upload your two images, again?
It's just one photo (courtesy of fellow board member unplugged): re-up
Thanks for uploading for a second time. Erixx Haxx has confirmed and I can also could also reproduce the problem.
:arrow: Reproduced
Re: 0.84: Set selection ratio
O.k., thank you, I can also reproduce the problem. Issue 1137 is fixed in next version.
This problem is supposed to be fixed in XnView MP 0.85 beta 1. Please check and confirm the bug fix here.
Confirmed fixed. (I'm not sure about the correct value of orientation. But selection ratios are correct).
