Hi everybody
In an old version of XnView it was possible to use the Print Screen button and paste this into XnView directly with Ctrl + V. (Import Clipboard) In the latest versions you have to use the function under tools which I find to be more complicated.
Is it me that do not know how to turn this feature on - or has it been removed?
Print Screen function - Paste into XnView with Crtrl+V
Re: Print Screen function - PrtScr - Paste into XnView with
Now it's Ctrl+Shift+VLars wrote:Hi everybody
Lars
ahh - Thank you! You saved my day!
Drahken
