Сканирую документы, закрываю создавшиеся вкладки с сохранением, возвращаюсь в браузер - там новые файлы появляются только после обновления содержимого папки вручную.
I scan documents, close the created tabs with saving files, come back to the browser - new files appear in it only after manually updating of folder contents by F5 or menu command.
Results of scanning aren't added to the browser
Re: Results of scanning aren't added to the browser
Yes, but I 'll have time to do this only in the second half of january.
I could reproduce this problem - not with scanned files but with screenshots. I'm not sure but I think the scenario is very similar or even the same - at least the outcome (bug) is the same.
Windows 7 64-bit
XnView 0.84 32-bit
1. Make a screenshot by pressing "PrtScr" key.
2. Start XnView.
3. Insert clipboard as new image by pressing "Ctrl+Shift+V"
4. Save screenshot image in current folder
5. Close the image
Actual behaviour (bug): In file list of XnView browser, the new image file isn't displayed at all (no thumbnail and no icon).
Expected behaviour: In file list of XnView browser a thumbnail of the new image is displayed.
Reproduced
Windows 7 64-bit
XnView 0.84 32-bit
2. Start XnView.
5. Close the image
O.k., thank you, I can also reproduce the problem. Issue 1239 is fixed in next version.
This problem is supposed to be fixed in XnView MP 0.87. Please check and confirm the bug fix here.
