0.84: Some context menu items unavailable after making copy
vertigo
Post by vertigo »
XnView: MP 0.84 x64
OS: Windows 7 - 64 bit
Effect: After making a copy of an image, the copy is selected but right-clicking it presents a context menu with the options 'Image data' and 'Convert into' grayed out until the file is deselected then selected again.
1. Select file in browser
2. Press Ctrl+C then Ctrl+V to make a copy of the file
3. The new copy will be selected. Right-click it to bring up context menu. Above options will be grayed out.
4. Deselect the file then reselect and right-click it. The above options are now available.
Actual behaviour (bug): Options that should be available are not
Expected behaviour: The options 'Image data' and 'Convert into' should be available without having to deselect and reselect the file.
Re: 0.84: Some context menu items unavailable after making c
Reproduced.
:arrow: Reproduced
O.k., thank you, I can also reproduce the problem. Issue 1121 is fixed in next version.
This problem is supposed to be fixed in XnView MP 0.85 beta 1. Please check and confirm the bug fix here.
vertigo
Post by vertigo »
Confirmed fixed.
