Steps:
1. Make sure that the zoom slider is in "Thumb columns" mode - IOW it should look like this:
2. Go to View | View As | Thumbnails + Details
3. Drag the slider pictured at step 1 to right and left
Expected:
The height should become bigger / smaller
Actual:
The height grows no matter what we do
0.84: Thumbs + Details = never ending growth
m.Th.
m. Th.
Re: 0.84: Thumbs + Detais = never ending growth
I could reproduce the problem (looks pretty strange).
Reproduced.
Re: 0.84: Thumbs + Details = never ending growth
It's not a bug, the slider works only in thumbnails mode
m.Th.
?!!!?xnview wrote:It's not a bug, the slider works only in thumbnails mode
The user expects to work... ...isn't it? (IMHO it quite easy to „fix” it - just use the same code in this case, either thumbnails mode either normal mode)
m. Th.
you would like that Size mode (not Thumbs mode) works in detail view to enlarge height?
PS: i can't use same code, it's another widget
m.Th.
Yes - sure. It is intuitive in this way. It isn't normal to change the mode when I want to alter the physical dimensions of the "parcel with the images".xnview wrote:you would like that Size mode (not Thumbs mode) works in detail view to enlarge height?
m. Th.
