0.84: batch renaming, enter key problem
phaolo
Post by phaolo »
XnView: MP 0.84 - 64 bit
OS: Windows 7 - 64bit
Browser mode, Batch Renaming dialog:
the ENTER key should push the "OK" button, not go to the previously used template!
Effect: risk of renaming the filenames incorrectly.
1- select a group of files.
2- select Rename to open the Batch Renaming dialog.
3- select the "create new name template when opening dialog" option.
4- click OK to rename (and to create an old template).
5- repeat points 1-3 with differently named files.
6- now press ENTER instead, to try to immediately accept the template and rename the files.
Actual behaviour (bug): previous used template selected :bug:
Expected behaviour: panel closed, files renamed with the first detected template
m.Th.
Re: 0.84: batch renaming, enter key problem
Post by m.Th. »
Confirmed.
Indeed it is dangerous: someone can incorrectly rename the files.
Easy to fix tough, I think.
m. Th.
phaolo
Post by phaolo »
I don't know if this was meant to be already fixed, but it's still present in 0.85
O.k., thank you, I can also reproduce the problem. Issue 1212 is fixed in next version.
This problem is supposed to be fixed in XnView MP 0.87. Please check and confirm the bug fix here.
