force desctipt.ion date to comment field ? HOWTO?
Xunk
Post by Xunk »
Hi.
Is there a way to get data from descript.ion files to be shown in the comment field? even if there is inline picture comment?
In the "old" version there was a separate column to be used in the detailed view... Is there a way in MP to mimic that behavior?
This is the final feature i need to switch entirely to MP. Please help.
Re: force desctipt.ion date to comment field ? HOWTO?
Currently if there is no comment, descript.ion is shown. So you would like to be able to show in detail view comment AND descript.ion?
Xunk
Post by Xunk »
Yes, that would be nice to have them as separate colloums
or
a way to choose between:
1. show comment, and if no commen show descript.ion.
2. show descript.ion, and if no descipt.ion show comment.
O.k., thank you. Issue 1249 is fixed in next version.
This problem is supposed to be fixed in XnView MP 0.87. Please check and confirm the bug fix here.
