0.85b2: Video volume is changed when changing mode
Dreamer
Post by Dreamer »
XnView: MP 0.85 beta 4 - 64-bit and MP 0.84 - 64-bit
OS: Windows 10 - 64-bit
Video volume has three different states, 1 for browser, 1 for fullscreen, 1 for viewer.
1. In Settings > Interface > Switching mode > set option for 2x click to "Browser>Fullscreen>Viewer".
2. Focus any video file in browser and set the volume to 0% (mute)
3. Click the "View" toolbar button to go to view mode
or
3. Double click the video file thumbnail to go to fullscreen
Actual behaviour (bug): Video volume is not at 0% :bug:
Expected behaviour: Video volume should be the same in all modes.
Dreamer
Re: 0.85b2: Video volume is changed when changing mode
Thank you for posting a separate bug report for this, Dreamer. I can confirm the problem (Windows 10). Volume level should be the same throughout XnView MP.
:arrow: Reproduced
O.k., thank you, I can also reproduce the problem. Issue 1226 is fixed in next version.
This problem is supposed to be fixed in XnView MP 0.87. Please check and confirm the bug fix here.
Dreamer
Post by Dreamer »
Original but fixed in 0.87 b1, but...
If I set 0% in fullscreen or viewer and switch back to browser mode, volume is not at 0%. To reproduce just set 0% in fullscreen or viewer and then switch to browser mode.
Dreamer
Dreamer wrote:Original but fixed in 0.87 b1, but...
ok, will be fixed in beta 2
Dreamer
Post by Dreamer »
Beta 2 update.
Previously reported bugs are fixed, but there are new bugs...
- select video in browser, volume 20%
- F11 to go to fullscreen
- set volume to 0%
- F11 to go to browser
- set volume to 20%
= volume is 0%
- set volume to 0%
- select another video file
= volume is 20%
It works the same also vice versa (20%/0%).
- go to viewer mode
- set volume to 0%
- go back to browser
- press play button
= volume is 20%
Dreamer
Dreamer
Post by Dreamer »
Fixed in beta 3, except this one.
Dreamer wrote:- select video in browser, volume 20%
- go to viewer mode
- set volume to 0%
- press play button
= volume is 20%
- then go back to viewer mode
= volume is 0%
Dreamer
