0.84: Multi-selection in browser: Wrong state of menu items
XnView: MP 0.84 - 64 bit
OS: Windows 10 - 64bit
When selecting multiple files in the Xnview browser the state (enabled/disabled) of the menu items "Open" and "Fullscreen" depends on the order of the multi-selection.
Effect: Irritating user-interface; expected functionality not available
0. In XnView browser browse a folder with image files (e.g. JPEG files) and non-image files (e.g. DLL files from XnView MP installation).
A1. Select a non-image file
A2. Enhance your selection by pressing Ctrl key and clicking on an image file
A3. Right-click on the image file to open the context menu.
Actual behaviour: menu items "Open" and "Fullscreen" are enabled.
A4. Close the context menu by pressing "Esc" key.
A5. Right-click on the non-image file to open the context menu.
A6. Close the context menu by pressing "Esc" key.
A7. Deselect all files
____
B1. Select an image file
B2. A2. Enhance your selection by pressing Ctrl key and clicking on a non-image file
B3. Right-click on the non-image file to open the context menu.
Actual behaviour: menu items "Open" and "Fullscreen" are disabled.
B4. Close the context menu by pressing "Esc" key.
B5. Right-click on the image file to open the context menu.
B6. Close the context menu by pressing "Esc" key.
B7. Deselect all files
Summary of actual behaviour (bug): State of the menu items "Open" and Fullscreen" in context menu depends on the order of your multi-selection. It does not depend on the contents of your multi-selection or on the image that you perform the right-click on. :bug:
Expected behaviour: Context menu must not depend on the order of your multi-selection.
Following screen video capture shows the above steps with four files: multiselection_fileliste.wmv.
m.Th.
Re: 0.84: Multi-selection in browser: Wrong state of menu it
Post by m.Th. »
Confirmed in 0.85b4 - Btw I was hit by this bug many times.
Other cases:
Problems with Shift.
If one Shift-selects several files AND the Shift-Select range does NOT span two rows of thumbs, the Open / Fullscreen are took from the last file ONLY.
If the last file selected is a non-openable file then Open / FullScreen is disabled for the entire selection.
If the last file selected is just an openable file (for example a .txt file) then Open is enabled but the FullScreen is disabled. If we click on Open, the navigation is broken tough: by clicking Next,Next,Next it shows only the images and not text files also
m. Th.
Re: 0.84: Multi-selection in browser: Wrong state of menu items
O.k., thank you, I can also reproduce the problem. Issue 1214 is fixed in next version.
This problem is supposed to be fixed in XnView MP 0.87. Please check and confirm the bug fix here.
