Steps:
1. Have some files on \\Server\Share\Dir 1
2. Select (some of) them
3. Drag them to \\Server\Share\Dir 2 (The same server and share from Step 1)
Expected: The files should be moved
Actual: The files are copied
0.86: Drag & drop: Copy instead of move in the same share
m.Th.
m. Th.
m.Th.
Re: Drag & drop: Copy instead of move in the same share
It will be fixed?
m. Th.
Re: 0.86: Drag & drop: Copy instead of move in the same share
O.k., thank you, I can also reproduce the problem. Issue 1274 is fixed in next version.
This problem is supposed to be fixed in XnView MP 0.87. Please check and confirm the bug fix here.
