- Open an image in the viewer.
- Go to Edit → Set selection ratio → 16:9 (1.78).
- Select an area of the picture.
- Click on the background of the viewer to undo the selection.
- Go to Edit → Crop... to enter “crop mode”.
- When you make a new selection, the ratio is still set to 16:9, but the drop-down menu on the crop toolbar says Free.
[0.86] Selection ratio in main menu and crop toolbar out of sync
Re: [0.86] Selection ratio in main menu and crop toolbar out of sync
It looks like this issue is about what I wanted to report. While cropping several pictures after each other, the actual crop ratio in use does not correspond to the ratio displayed in de left top crop drop down menu. In fact, in most cases it uses the latest ratio selected. This is however not correctly displayed when one switches to the next picture in the directory. This issue behaves like this in the latest versions including XnView Mp 0.86. Please investigate what is displayed and used in the code. These are definitely different values for the aspect ratio.
Regards Peter
Regards Peter
O.k., thank you, I can also reproduce the problem. Issue 1254 is fixed in next version.
This problem is supposed to be fixed in XnView MP 0.87. Please check and confirm the bug fix here.
Not fixed in beta 1 and 2xnview wrote:This problem is supposed to be fixed in XnView MP 0.87. Please check and confirm the bug fix here.
i can't reproduce in beta 2, always freeXnTriq wrote:Not fixed in beta 1 and 2xnview wrote:This problem is supposed to be fixed in XnView MP 0.87. Please check and confirm the bug fix here.
Yes, the value of the drop-down menu on the crop toolbar is still set to Free, but isn't that a bug?xnview wrote:i can't reproduce in beta 2, always free
7. Expected behavior (at least for me): The value in the drop-down should change to 16:9 (1.78) to match the value in Edit → Set selection ratio.XnTriq wrote:
when you enter in crop bar, the ratio is always set to free
I agree with XnTriq. The values should match. Why does the crop board reset the value?
Rich
Rich
ok i'll change the behavior in beta 3richlux wrote:I agree with XnTriq. The values should match. Why does the crop board reset the value?
The values now stay in syncxnview wrote:ok i'll change the behavior in beta 3richlux wrote:I agree with XnTriq. The values should match. Why does the crop board reset the value?
