0.86: Keep Ratio and Preset Sizes Issues
ckit
Post by ckit »
- Open an image into Viewer mode from Browser mode
- Use either Resize... or Canvas Resize...
- Uncheck "Keep Ratio"
- Choose "1920x1200" from the Presets
- "Keep Ratio" is re-activated and size is set to "1920x1506" when it should be "1920x1200"
XnView Classic 2.40 does not have this issue!
Re: 0.86: Keep Ratio and Preset Sizes Issues
Thank you for reporting this bug, ckit. I could reproduce your problem and confirm this bug.
:arrow: Reproduced
O.k., thank you, I can also reproduce the problem. Issue 1206 is fixed in next version.
This problem is supposed to be fixed in XnView MP 0.87. Please check and confirm the bug fix here.
ckit
Post by ckit »
Confirmed with XnViewMP x64 0.87 beta 2
