0.86 MacOS: "View » Reset X/Y" does not work.
nglazov
Post by nglazov »
XnView: MP 0.86 - 64 bit
OS: Mac
Propertie of View Reset XY does not work.
Effect: View glitch
You have to have 2 large images in folder
1. When you are in browser view set option Reset XY to on
2. Open first image
3. Scroll it down
4. Go to next image
Actual behaviour (bug): XY position are the same like on previous image :bug:
Expected behaviour: XY position should be equal 0
Re: 0.86: "View » Reset X/Y" does not work.
Same here: I've tried to reproduce your problem on Windows 10 but here it works fine. :? Looks like another XnView problem which occurs on MacOS, only.
What is your setting of "Auto image size"?
nglazov
Post by nglazov »
helmut wrote:Same here: I've tried to reproduce your problem on Windows 10 but here it works fine. :? Looks like another XnView problem which occurs on MacOS, only.
The value is "Last used" but i tried different values.
Re: 0.86 MacOS: "View » Reset X/Y" does not work.
O.k., thank you, I can also reproduce the problem. Issue 1261 is fixed in next version.
This problem is supposed to be fixed in XnView MP 0.87. Please check and confirm the bug fix here.
