Hi Folks!
1. When I select two or more images and press Shift-C a window opens in compare mode.
The top-left image is selected.
In the filmstrip below *no* image is selected.
This is a bit confusing. Can you select the corresponding image in the filmstrip on opening of the compare window?
2. In the compare window Ctrl-T for tagging an image does not work. Could you make it work?
That's all for now!
Regards from Holland
Germie
0.86 Compare mode
Re: 0.86 Compare mode
O.k., thank you, I can also reproduce the problem. Issue 1266 is fixed in next version.
This problem is supposed to be fixed in XnView MP 0.87. Please check and confirm the bug fix here.
Tested with 0.87 beta 3, fixed.
First tested with 0.86 and confirmed the behaviour posted by Germie.
In 0.87 beta 3, after selecting 4 files and pressing Shift-C for compare, the first file is also selected in the filmstrip.
After pressing Ctrl-T the file is also tagged in the filmstrip.
