0.86: Create "joing images", "Multipage", etc. based on DNG ignoring the embedded preview
cadu
Post by cadu »
Since my "settings>view>camera raw use embedded preview" is selected, I was expecting that any output based on DNG files from menu "create" (joing images, multipage, etc.) would be using the embedded preview to generated those outputs.
However, the outputs are generated are based on the raw file without any adjustments.
I tried this process using similar tools in FastStone viewer, which considers the embedded preview to generated its outputs, what I consider the correct behavior.
Could you please inform if XnView functionalities under menu "create" can be used based on the DNG embedded preview, instead of raw?
I'm expecting XnView could work as FastStone Viewer.
Otherwise, it may be a bug which is happening with XnView.
I recorded my screen showing the issue: https://goo.gl/S6xOLi
Thanks!
Carlos_Cadu
Re: 0.86: Create "joing images", "Multipage", etc. based on DNG ignoring the embedded preview
O.k., thank you, I can also reproduce the problem. Issue 1265 is fixed in next version.
cadu
Post by cadu »
Thanks Pierre!
This problem is supposed to be fixed in XnView MP 0.87. Please check and confirm the bug fix here.
