Move To resets file date
svesjo
Post by svesjo »
When I use Move To (Ctrl-M) to move files from my camera to a folder on my server, the file date is reset to 01.01.1601.
The exif date is unchanged.
Copy To (Ctrl-C) is OK.
Moving files to a local folder is OK.
XnView MP Windows Version 0.86 64bits (Apr 25 2017)
Windows 10 pro, latest update.
Server is running Windows Small Business Server 2011 Standard.
The camera is connected via USB cable.
Re: Move To resets file date
are you able to reproduce with files from other folder too??
xpilot
Post by xpilot »
same effect here using drag and drop for moving files between folders within a shared drive on a Server.
Not all files are affected. Only a few of each moved batch.
Windows 10 Pro on client, running XnView MP Windows Version 0.86 64bits (Apr 25 2017)
Server is Windows Homeserver 2011 (Windows Server 2008R2)
xpilot wrote:same effect here using drag and drop for moving files between folders within a shared drive on a Server.
do you have the same problem between drive not server?
xpilot
Post by xpilot »
sorry for late reply.
xnview wrote:do you have the same problem between drive not server?
No, moving on local drives works perfect without reset of file date. I did some tests:
Moving local to local: works
Moving local to server: reset
Moving server to local: works
Moving server to server: reset
File copy works for all of the above mentioned directions without issues.
Are there any XnViewMP debug log files I can provide?
O.k., thank you, I can also reproduce the problem. See issue for current status and some details. I'll post here once the problem has been fixed.
This problem is supposed to be fixed in XnView MP 0.88. Please check and confirm the bug fix here.
This problem is supposed to be fixed in XnView MP 0.89. Please check and confirm the bug fix here.
HanVroon
Post by HanVroon »
Able to reproduce with 0.86, most of the 20 moved files got date 01-01-01.
(working on a share, moving between directories on that share)
Tested with 0.89, fixed.
Did several moves of 20 files, all time the date wasn't changed anymoer.
