Photo App and lossless rotation
Photo App of Windows 8.1 and 10 is able to apply lossless rotation of images whose dimensions are not multiple of 8 and the images are not cropped. Photo App modifies Exif orientation. I opened the images in PowerDirector and they are rotated
Please add this feature to XnViewMP too
Re: Photo App and lossless rotation
Please activate Change EXIF orientation ONLY (if possible) in Tools → Settings... → Browser → Misc..Plotino wrote:Photo App modifies Exif orientation.
Yes I did, but it doesn't work. Rotation is always lossy. If I check even "Use lossless rotation (if possible)" XnViewMP crops the image, and I don't want this.
Photo App does a lossless rotation of the image I attached, XnViewMP doesn't
Strange, i have tested with 'Change EXIF orientation' checked, and 'Use lossless rotation' not checked, and this is the result
There is no EXIF, so XnViewMP can't change the EXIF orientation field, so picture is re-saved (without cropping)
No problem to rotate without crop, as you said, simply leave 'Use lossless rotation' not checked
Rotation isn't lossless
I don't know how it does, but Photo App applies lossless rotation.
You can test with Paint.NET
open the copied, rotated file.
Edit...Select All
Edit...Copy
File...Open (..then specify the original file)
Edit...Paste into New layer
Layers...Layer Properties...Difference
Image...Flatten
Adjustments...Auto-Level
if the result is a black image the rotation is lossless
Please, investigate Photo App behavior. Imho it's important
Edit...Select All
Edit...Copy
Image...Flatten
I used Exiftool to obtain information from the picture before and after Photo App rotation.
Before
After
As you can see, there is this new value "Orientation: Rotate 270 CW"
So Photo App write info in Exif.
After that the image is rotated with Photo App I can perform rotation with XnViewMP as you did, but only now the rotation is lossless
Before
ExifTool Version Number : 9.03
File Name : lav (04)_1377164681_675x0.jpg
Directory : F:/Documenti/Download/Y - Video - Audio Editing/MkvToMp4_0.224/Tools/ExifTool
File Size : 114 kB
File Modification Date/Time : 2017:06:03 17:26:11+02:00
File Access Date/Time : 2017:06:03 17:26:06+02:00
File Permissions : rw-rw-rw-
File Type : JPEG
MIME Type : image/jpeg
JFIF Version : 1.01
Resolution Unit : None
X Resolution : 1
Y Resolution : 1
Comment : CREATOR: gd-jpeg v1.0 (using IJG JPEG v62), quality = 95.
Image Width : 675
Image Height : 450
Encoding Process : Baseline DCT, Huffman coding
Bits Per Sample : 8
Color Components : 3
Y Cb Cr Sub Sampling : YCbCr4:2:0 (2 2)
Image Size : 675x450After
File Size : 130 kB
File Modification Date/Time : 2017:06:07 15:24:07+02:00
File Access Date/Time : 2017:06:07 15:24:07+02:00
File Type : JPEG
JFIF Version : 1.01
Resolution Unit : inches
X Resolution : 96
Y Resolution : 96
Exif Byte Order : Big-endian (Motorola, MM)
Processing Software : Windows Photo Editor 6.3.9600.17418
Orientation : Rotate 270 CW
Modify Date : 2017:06:07 15:24:03
Padding : (Binary data 2060 bytes, use -b option to extract)
About : uuid:faf5bdd5-ba3d-11da-ad31-d33d75182f1b
Creator Tool : Windows Photo Editor 6.3.9600.17418
Image Width : 675
Image Height : 450
Bits Per Sample : 8
Image Size : 675x450So Photo App write info in Exif.
I can confirm that lav (04)_1377164681_675x0.jpg doesn't contain any EXIF infoxnview wrote:There is no EXIF, so XnViewMP can't change the EXIF orientation field, so picture is re-saved (without cropping)
How-To Geek ([url=http://www.howtogeek.com/254830/why-your-photos-dont-always-appear-correctly-rotated/]Why Your Photos Don’t Always Appear Correctly Rotated[/url]) wrote:For example, on Windows 7, Windows Photo Viewer and Windows Explorer ignore the Exif Orientation tag. Windows 8 added support for the Exif Orientation tag, which continued into Windows 10. Images may appear correct on a Windows 10 or 8 PC, but rotated differently on a Windows 7 PC.
Modern smartphones and digital cameras have faster hardware, so it should be possible for them to save photos in an already-rotated state instead of just applying the Exif Orientation tag. Unfortunately, the industry seems to have settled in Exif Orientation tags as the standard solution, even if they aren’t ideal.
Maybe Photo App adds Exif information?
Try the same step I did
Photo App lossless rotation is a fact, it isn't my opinion
I'm sure you're right, Plotino! Thing is that I don't have access to Windows 8/8.1 or 10.Plotino wrote:Photo App lossless rotation is a fact, it isn't my opinion
Could you please upload the original and processed files so Pierre (and the rest of us) can have a look at the EXIF injected by Windows Photo Editor?
Thanks for your patience
- Attachments
- images.zip
- (244.02 KiB) Downloaded 243 times
O.k., thank you, I can also reproduce the problem. Issue 1204 is fixed in next version.
Please, add this type of rotation to View and Slideshow mode as well
This problem is supposed to be fixed in XnView MP 0.87. Please check and confirm the bug fix here.
Yes, pictures are now rotated altering the Exif orientation.
This is very good for images whose dimensions are not multiple of 8, however pictures whose dimensions are multiple of 8, IMHO, should be rotated in the standard lossless rotation way. I mean according to jpegtran rules
