I have a huge amount of .CDR pictures I created long long time ago using Corel Draw 3.0. With XNView, I am trying to open them and all I get is thumbnail like format pictures, with no details. Some graphic files, for instance, have text and when opened in XNView, all I see is a small rectangular black box. Below is a comparison of original CDR (Left) and view in XNView (Right) :
http://img123.imageshack.us/img123/5013 ... iew9sg.jpg
What should I do to open these vector based .CDR?
Luke123
Problem opening .CDR files...
Re: Problem opening .CDR files...
XnView can only extract thumbnail from CDRLuke123 wrote:I have a huge amount of .CDR pictures I created long long time ago using Corel Draw 3.0. With XNView, I am trying to open them and all I get is thumbnail like format pictures, with no details. Some graphic files, for instance, have text and when opened in XNView, all I see is a small rectangular black box. Below is a comparison of original CDR (Left) and view in XNView (Right) :
Luke123
Luc
"Many users want only thumbnail, and XnView doesn't support vector files."
Yes, but tell me. What is the use for thumbnails? What are they made for if you can't open them fully up?
Usually a thumbnails is a display of a collection of images, represented as reduced sized graphics that we usually visualize when needed by clicking on them.
So what other "service" can I expect from thumbnails?
Luke123
Luke123
To organise files for example, and often they use "Open with"Luke123 wrote:"Many users want only thumbnail, and XnView doesn't support vector files."
Sorry but CDR is a closed format...
If you do not use the XnView Browser, you will not know about the benefit of thumbnails. Thumbnails give you a good idea of the image's contents and allow for organzing your images. Sure enough, if you want to edit the images, you have to open them. As Pierre has pointed out, the .cdr format is proprieratary, i.e. no tool other than Corel Draw will be able to open and display it.Luke123 wrote:Yes, but tell me. What is the use for thumbnails? What are they made for if you can't open them fully up?
So for browsing and managing your CDR images you could use XnView, and when editing you could use XnView as a start platform. See details in FAQ "How can XnView interact with other (graphic) programs?".
Sure enough XnView is not the cure for all use cases, but for many people it works quite well.
