v.86 Copy-Paste Auto-naming Discrepancy
Brother Gabriel-Marie
Post by Brother Gabriel-Marie »
Today I working with some jpeg files. I copied one and pasted it like I always do, knowing MP will append " - Copy" to the filename.
However, it didn't work right this time.
Old Name:
Autoname:
You can easily see what the problem is.
XnView version .86 x64 on Windows 7
Re: v.86 Copy-Paste Auto-naming Discrepancy
The problem will be fixed in 0.87 beta 2
Pierre, you are wonderful. I should say that more often.
HanVroon
Post by HanVroon »
Tested with 0.87 beta 2 (after first unchecking Add "copy of" for duplicate filenames), fixed.
The program now looks for the last dot in the filename, right? :D
"- Copy" is added to the end of the filename correctly.
