Wrong Collage
Lupus52
Wrong Collage
Post by Lupus52 »
I found the following BUG.
I have 165 JPGs. (large geo-map). Collaged should this be a map with 10 Rows and 15 Columns.
The JPGs are squareformat. 700x700
Only the last colum and the last row have another sitze.
The most right pictures have the same hight like all. But only 200 in width
The lowest JPGs have full width like the other but only a hight of 400
And the absolute last is 200 x 400
XNVIEW adds the last JPG in a row correct. I have 14 and a half Pictures side by side
But the lowest row ist scrambeld. XNVIEW tries to stretch the absolute last JPG in 2 directions. Ans with the result ist deforms the othe in the last row.
I have reduced my 165 JPGs for testing to 15. It means 3 rows with 5 cols.
Explorer shows the last picture stretched. It has only 200x400
When I use the collagefunktion the result looks like this:
This is scrambeld too in the last row.
The 1. and the 2. Rows are ok. The last (3.) row starts correct. But the rest is stretched to 1 1/2 rows
I have placed these 15 JPGs in http://www.gerud.de/XNVIEW/Testmap.zip
It would nice if you can fix this bug (unnecessary stretching the last row/col picture)
Lupus52
Re: Wrong Collage
Post by Lupus52 »
No answer :x
Re: Wrong Collage
Confirmed :bugconfirmed:
Expected result (Click on preview opens animation)
Lupus52
Re: Wrong Collage
Post by Lupus52 »
XnTriq wrote:Confirmed :bugconfirmed:
Hello and thank you for the answer. But I don't understand it.
Is the bug report accepted or is the the bug fixed? You show a nice GIF with a correct displaying of te map. What do you want so say?
Best regards
Re: Wrong Collage
Hello Lupus52
I'm sorry you had to wait for a response to your bug report. Pierre (the developer of XnView) will have to look into the problem.
I created that GIF animation to illustrate how these “tiles” need to be stitched together for the correct outcome.
Re: Wrong Collage
ok, the problem can be reproduced. Issue 1308 is fixed in next version.
Re: Wrong Collage
This problem is supposed to be fixed in XnView MP 0.88. Please check and confirm the bug fix here.
Re: Wrong Collage
This problem is supposed to be fixed in XnView MP 0.89. Please check and confirm the bug fix here.
HanVroon
Re: Wrong Collage
Post by HanVroon »
Reproduced in 0.87 with the 15 provided images.
Tested with 0.88 and 0.89 beta 2, Fixed.
The collage is now correctly built.
Re: Wrong Collage
HanVroon wrote:Reproduced in 0.87 with the 15 provided images.
Confirmed :bugfixed:
