"Most common" file types
In the options dialog, category "Write > File types" the user can set the file types shown for opening and saving. There's a button "Most common" for the most often used file types.
When selecting the button, many file types are checked, including "Amiga IFF", Portable Bitmap, Portable Pixmap and some more. Instead, I'd expect only:
- GIF
- PNG
- JPG
- BMP
- TIF
- PCX
to be checked on a Windows platform. This will increase user comfort especially when saving files, since the user can choose the format in a short list.
On Unix the list of most common formats may differ, probably we need different lists per platform for the most common formats.
Dreamer
Post by Dreamer »
Right, I agree.
Re: "Most common" file types
helmut wrote: - GIF
- PNG
- JPG
- BMP
- TIF
- PCX
Only these formats?
marsh
Post by marsh »
I agree that list should be relative to OS. My file types match Helmut's list, except PCX.
marsh wrote:I agree that list should be relative to OS. My file types match Helmut's list, except PCX.
Ok, and perhaps by default??
marsh
Post by marsh »
Yes, that would be better.
Dreamer
Post by Dreamer »
I agree.
Thank you all for your comments. Looks as if we all agree. :-)
Three things left:
1.) What should we do with PCX? List it or not?
marsh things that PCX is not a common format, and I also think that PCX is rarely. So it should not be part of the list.
2.) What should the list for UNIX look like? Perhaps:
JPG
PNG
GIF
TIF
PBM
PBX
Not sure, here, I don't have Linux or similar. Perhaps TGA is used on Sun Workstations?
3.) Is a third list for MAC needed?
No clue, here. Perhaps a MAC user can tell.
Irving
Post by Irving »
I run Windows, and these are all I ever select:
- GIF
- PNG
- JPG
- BMP
- TIF
helmut wrote:T
I think that we must add tga because it's a very used format on windows
xnview wrote:
helmut wrote:T
I've just searched all my fixed drives and found 3 TGA files in about 100.000 files. Are you sure that .tga is important on Windows?
I think ".ras (Sun raster files)" might be important on Sun workstations, but I'm just guessing.
Not any---
:arrow: Pierre
:) Hello Pierre !
- Worse than Helmut : here, in two PCs and approx. 70,000 files, I didn't find out ONE *.tga, nothing !
:mrgreen: Kind regards,
Olivier_G
Post by Olivier_G »
Same here: I use only JPG, TIF, PNG, GIF and BMP
Synthesis---
:arrow: Olivier_G
:) … same, plus *.ico, I like to draw my own ones ;)
- Pierre could make a convenient synthesis with this suggestion, as its full version…
:mrgreen: KR
I agree.
But perhaps a problem for users that don't see TGA as output format the first time!!
